We know that getting started with a new app often comes with questions.
In this post, we’ve gathered the most common ones about the AI Chatbot widget to help you get the smoothest experience possible ![]()
General
Which language model does the AI Chatbot use?
The AI Chatbot runs on the GPT-6-luna model.
If you’d like to switch to a more advanced version, please upvote this idea:
Ability to switch to GPT-5
What’s the typical response speed of the AI?
The AI usually responds within 5–10 seconds. If it takes much longer, this may happen due to an overly long or complex instruction.
Try simplifying your instruction. If that doesn’t help, let us know — we’ll gladly check it for you ![]()
If I copy the widget, will the knowledge base be kept?
Unfortunately, no. When you copy a widget, the assistant’s training data isn’t duplicated — you’ll need to train it again.
If you’d like this feature added, please upvote this idea: Duplicate the widget with the Knowledge Base.
How does the Language setting affect my messages?
The Language setting defines the email language, time format, and some interface text.
It doesn’t affect the chatbot’s language — the bot will respond in whichever language your users speak.
Can the widget elements be translated automatically based on my website’s language?
This feature isn’t supported yet, but it’s already on our Wishlist.
You can upvote the idea here: Multilanguage version for the widget elements
Chat history email and contact form
How does the 'Send Chat History to Email' feature work?
After 5 minutes of inactivity, the chatbot sends a follow-up message (if enabled).
After 10 minutes, the chat closes and the conversation is sent by email (if configured).
Inactivity means no input from the user.
When is a chat history email sent?
An email will be sent if:
- There’s been no activity for 10 minutes
- ‘Send Chat History to Email’ is enabled in the configurator
- The chat is not happening inside the configurator
How long are chat histories stored?
All chat histories are stored indefinitely — we don’t delete any conversations.
Can the bot send a contact form during or after a conversation?
Currently, the form can only be sent with the greeting message or after the first reply.
If you’d like to send the form during a chat, please upvote this idea:
Send contact form during chat
Can I add custom fields to the contact form?
For now, only default fields can be added:
- Name
- Phone Number
- Consent Checkbox
Please upvote this idea if you’d like to see the custom fields in the future: Custom form fields (Text field, Choice, Date, Time, etc)
Can I make form completion required before continuing the chat?
Yes, this feature is available in the widget:
Can chat history emails be white-labeled?
Not yet — this feature is also on the Wishlist. You can support the idea here: Ai chatbot Chat History to Email (white label)
Can I send chat histories to website visitors?
This feature isn’t available yet, but you can upvote the idea here:
Send chat history to website visitors
In the meantime, users can manually copy the transcript using the button in the chat header:
Message & Storage Limits
What’s the storage limit for files and data?
Storage depends on your subscription plan:
For files: 1 char = 1 byte
For text blocks and Q&A: 1 char = 1 symbol
How can I check my current storage usage?
At the moment, it’s not possible to track your storage usage, but this feature is on our Wishlist.
You can upvote it here: Display Remaining Chars
If needed, we can check your current usage for you — just let us know.
What’s the message limit for the AI Chatbot?
Message limits depend on your subscription plan:
Only user messages count toward the limit — not chatbot replies ![]()
Is there a message limit per conversation?
Yes, there is a limit of 100 messages within one conversation thread. This limit is set to maintain good performance. Custom limits or message counting to warn users are not possible.
What happens when the message limit is reached?
When the limit is reached, the widget will deactivate and disappear from your site. You’ll see a notification in the configurator.
The message limit resets monthly, on the day your Lite or paid subscription was created. If you don’t want to wait until the limit is reset, you should upgrade your subscription plan. ![]()
Do messages sent during training count toward the limit?
Each user gets 100 free messages for testing the chatbor from the configurator on monthly basis ![]()
Once you hit that limit, any additional messages sent from the configurator will count toward your overall limit.
Education & Instructions
Where can I find training tips for smoother performance?
We’ve collected key training tips in these guides:
Best Practices for Training Your AI Chatbot Widget - Elfsight Help Center
Step 1: Set Up Your AI Chatbot Knowledge Base - Elfsight Help Center
If your bot still gives inaccurate answers or behaves unexpectedly, share your use case with us — we’ll be happy to help! ![]()
How can I make the bot send URLs as clickable links?
Check out this guide: How to add a hyperlink to your AI Chatbot.
How does the AI use Q&A and Text Blocks?
Q&A and Text Blocks help the AI learn about your business, but it doesn’t quote them word-for-word.
Instead, the model combines information from different sources, which may sometimes lead to small inaccuracies.
How do I train the AI assistant with a URL?
When you add a URL, the chatbot uses your site to gather basic information and build an initial instruction — it doesn’t train directly on the site content.
Make sure your website uses HTTPS, as HTTP isn’t supported.
How many web pages can I add to the AI Chatbot?
You can add up to 200 web pages. The chatbot will use the content from these pages to respond to user inquiries.
Want to add more training URLs? Please upvote this Wishlist idea - Remove/increase limit for Web Pages.
How can I update the web pages in the widget?
If your website content changes, click Retrain to refresh the chatbot’s knowledge.
If you’d like the bot to update automatically, please upvote this idea:
Automatically update the knowledge base after any changes made on the page or after set interval (training with URLs option)
What if my website is password-protected?
The chatbot can’t access password-protected pages. You’ll need to manually add the information you’d like it to use.
Didn’t find what you’re looking for? Drop your questions below, and we’ll be happy to help ![]()
