Update AI Chatbot plan
Hello @Max
How can we update just the AI chatbot license?
Because we see still this pricing:
Thanks, Piero
Hi @Piero_Biasi1 :wave:
Yep, the info about message limits hasn’t been added to the Pricing page yet, but we’re planning to update that soon.
However, if you check the AI Chatbot pricing from your dashboard, you’ll see the message limits for each plan:
Thus, if you’d like to increase the message limit, you can upgrade your subscription now. In case you need any assistance with it, please contact our Support Team at support@elfsight.com. They’ll be happy to help :wink:
Hello @Max
I cannot see that information. See here - there is no “upgrade”.
So, can we just update just the AI chatbot license?
Hi there :wave:
If I got you right, you’d like to keep your All Apps Basic plan subscription and add a separate subscription for the AI Chatbot with a higher plan.
If it is, please contact our Support Team at support@elfsight.com. They’ll be happy to assist you with it :slightly_smiling_face:
