Limit messages per widget
An option to limit messages numbers. for example i want to limit one widget ai messages 100. If widget reaches that limit, widget should deactivated or hide automaticly
Hi there, @Burak_Arda :wave:
I see you’re using the AI Chatbot on the Free plan, which gives you a limit of 100 messages per month. Once you hit that limit, the widget will be deactivated. So, now everything works the way your requested.
Just to clarify, are you asking about the higher plans? For example, if you upgrade to the Basic plan with 300 messages, the limit would be split evenly between 3 Chatbot widgets, giving you 100 messages per widget. Am I right?
Hi. Yes i am asking this for higher plans if i use multiple chatbot widgets. Elfsight limits are usually count by total. I don’t want one widget to use all limits. This should be an option also for other widgets, like instagram widget views by the way. If not exists.
Got you, thanks!
We’ll try to consider this opportunity in the future, especially if more users support this idea :slightly_smiling_face:
Yes, this would be a really good feature! Especially when managing multiple websites!
Definitely a great feature!
I totally agree.
Thank you so much for your comments, @Joshua5, @Tech_Guy!
If this request becomes popular, we’ll try to consider it in one of the future updates :slightly_smiling_face:
