Twitter posts don't appear
HI,
I create my first Social feed for testing.
Facebook and Instagram posts are displayed, but thera are not Twitter posts.
I obtain this error: Twitter: Error: Service is unavailable now
Can you help me please?
Thank you,
Giusy
Hi @user3810
We are thrilled to see you on board! Welcome :tada:
I see that my colleague Anna has already contacted you. As she said, we’re currently experiencing issues with the Twitter API, which is causing this connection issue. I’m terribly sorry!
By September 12 the issue should be eliminated. So if you could reconnect your Twitter account on Tuesday - everything should work correctly!
To reconnect your widget, please disconnect your widget from the Twitter account and connect it again.
If any further questions come up, feel free to contact Anna. She’ll be happy to help!
Last week I sent you a problem on Twitter posts, but I didn’t get any response.
To decide whether to use your Social Feed, I need to know if it works with all the social networks I’ve tested.
Thank you
GB
Ok, thanks, I will do it.
Ignore my message from before: I hadn’t seen your reply.
Thank you
No problem!
You are always welcome :wink:
