No Twitter posts on new connection
Hello, I’ve just created a new Social Media widget connection to Twitter - and get a “Twitter: Service is unavailable now. No posts to display. The specified resources might be empty, or there could be set filters not satisfying any post.” message.
The last actual post was 4 days ago. Do I need top wait for Elfsight to connect and build its cache, or is there something wrong with the connection? It looks ok to me.
A test page is www.openbright.org.uk/test-twitter
Hey there @Andy_Roberts and welcome aboard :wave:
I am sorry to say that we’re currently experiencing issues with the Twitter API, which is causing troubles in collecting tweets.
The maintenance will be finished on July 10. On July 10, please reconnect your widget and publish it. After that, the tweets should make it into your feed!
I’ve already disconnected you and cleared the authorization data on our side to make sure the reconnection goes smoothly :slightly_smiling_face:
Let me know if you have any further questions.
Thanks Max. That’s fine - I had just assumed I was doing something wrong! (Thanks for the quick response)
No problem! You are always welcome :wink:
