Issues with Social Feed Widget - Only Displaying 3 Twitter Posts and Problems with Multiple Twitter Accounts
Hi everyone,
I’m having some issues with the Social Feed widget on my website. The widget is supposed to display posts from both Facebook and Twitter. Here are the two main problems:
1. Twitter Posts: The widget only displays the first 3 posts from Twitter, and subsequent posts do not appear. I want all posts to be displayed.
2. Twitter Accounts: The widget only displays posts from one Twitter profile, even though it should display posts from two different profiles. Both profiles are added in the settings, but the widget shows posts only from one of them.
Note: The Facebook posts are being displayed correctly, so the issue seems to be only with the Twitter integration.|
Has anyone else experienced similar issues and can offer some advice? I would appreciate any tips on how to resolve these problems.
Hi @Michalina_Szostak :wave:
Could you please send me a link to the page where your widget is installed or just specify the widget ID?
Hello @Max ,
thank you for replying
https://projektik.eu/
not sure where I can find the widget ID
Thanks!
Most of the posts in 2 Twitter accounts are retweets and replies. In the filters, you’ve chosen to show only tweets, that’s why you see only 3 posts. If you enable Show Retweets and Replies, all the other posts will be displayed too:
Thank you so much for your help! It was so useful.
Regards!
You are always welcome :wink:
