Twitter feed not showing
Hello, I am trying to create a social feed with LinkedIn and Twitter. The Linkedin posts are appreaing but none of the Twitter posts, replies or reposts are showing. How can I fix this?
Hi there @Jayashree_Nandi :wave:
I am sorry to say that we’re currently experiencing issues with the Twitter API, which is causing troubles in collecting tweets. I’m terribly sorry :pensive:
The maintenance will be finished on August 10. On August 10, please reconnect the Twitter source and Publish changes. After that, the tweets should make it into your feed!
I’ve already disconnected you and cleared the authorization data on our side to make sure the reconnection goes smoothly.
Let me know if this explains things or if you have any questions left :slightly_smiling_face:
Got it, thanks Max! Will try after August 10.
Has there been any follow up to this Twitter API issue being fixed? We are also still having no Twitter post in our feed. Is there a reset on your end we need for this? Thanks
Hi @Danetta_Smith, happy to welcome you to the community! :wave:t2:
I’m really sorry about this inconvenience. The good news is that the issue is fixed, could you please try to reconnect the source and let me know if it worked?
Thank you - yes it does now seem to be working - when I reconnected yesterday it wasn’t. Maybe a little time was needed. Thank you for the follow up!
Great, thanks a lot for the update!
And you’re always welcome :smiling_face:
