Squarespace has the following Carousel types.
- List Section Carousel (People Section)
- Gallery Block - Carousel
- Summary Block - Carousel
Additionally, you can use these plugins to create a carousel, it has more advanced features, and you can customize the slider more.
- WM Sliding Banner
- Image Slider
- Logo Showcase carousel
- Reviews Carousel (Google, Facebook, Booking,…)
You can follow these steps to add a Carousel.
A. List Section Carousel (People Section)
You need to add a List Section to change it into a List Carousel
#1. First, choose the page that you want to add a List Section and click Edit
#2. Next, you click ADD SECTION
#3. Choose the People and add the List Section (section with (i) icon )
#4. Next, hover on the List Section and choose EDIT CONTENT
#5. At Design , click on Simple List and change it to Carousel
you will have
B. Summary Block Carousel
#1. You need to add a block first, then choose Summary Block from the list.
#2. Next, choose Edit the Summary Block
and change it to Carousel.
and result.
C. Gallery Block Carousel
#1. First, you need to add a Gallery Block.
#2. Choose Edit the Gallery Block
#3. At Design, you choose Carousel
D. Gallery Section - Reel
#1. First, you need to add a Gallery Section.
#2. Next, you hover on the Gallery Section and choose EDIT SECTION
#3. Next, you click on Grid: Simple and change it to Slideshow: Reel
Result
