Google Reviews: No reviews found issue
Dear friends,
Unfortunately, our Google Reviews widget is experiencing some technical issues at the moment that result in reviews not being collected.
It is our top priority to get everything back on track as soon as possible, and our developers are already working on a solution. After the fix is ready, it will be automatically applied to your widget, you won’t have to do anything on your end.
We will immediately get back to you as soon as we receive any news from the developers.
Thank you for your patience and understanding :pray:
I am happy to say that issue is fixed :tada:
All your widgets should be working fine!
