Google Reviews: Issue with review collection [Fixed]
Hi Elfsight team!
For some reason, I’m having issues pulling Google Reviews using All In One Review. Yelp seems to work just fine. I cannot find the business using the business name and location, so I used Google Maps link. However, it still doesn’t work. There are just 5 reviews. They are ranging from 1-8 years old, not new reviews. Please see attached file for reference. I tried recreating it and I’m still getting the same thing.
Welcome to the Community, @user3615 :waving_hand:
I am so sorry for this inconvenience!
I’ve forwarded this issue to the devs and will update you once it’s fixed :slightly_smiling_face:
Help! me too !
Hi @user33303 :waving_hand:
I deeply apologize for this!
I’ve also shared your source with the devs and will let you know once it’s fixed.
Guys, I am sorry to say that our review provider encountered an issue with the collection of the reviews from new sources and they are doing their best to resolve it as soon as possible.
@user3615, I am glad to say that we’ve manually resynced your source and the reviews have been collected. Could you please check if it’s fine now?
@user33303 I am really sorry, but only 18 reviews have been collected in your widget. Our review provider is doing their best to fix the issue globally.
Once the global fix is released, we’ll be able to resync your source to collect all reviews. We’ll immediately update you as soon as we have more news.
  • Issue description: Hi there, when I enter my google business page it’s find it but can’t find the review. I know this issue has been addressed before but last post is from 2023 and it doesn’t seem like there is a way to fixe it by myself ? Is there still some technical issues or is there something I can do ?
  • Link to the page with the widget in question: Google Search
Hi there, @Oriane_V :waving_hand:
At the moment, we’re experiencing issues with the collection of the reviews from new sources and our devs are doing their best to resolve it as soon as possible.
We’ll update you here once the issue is fixed globally.
The good news is that we’ve manually reset your source and the reviews have been successfully collected. Please check your widget and let me know if it’s fine now :slightly_smiling_face:
Hey @user33303!
I am happy to say that the issue with your widget was resolved. Please check it out and let me know if all reviews have been collected on your end :slightly_smiling_face:
@Max @Helga
Hi,
I am getting the spinning wheel of doom. “The Reviews are being collected, please wait for a few minutes. “
I have followed the directions found here How to Add Google Reviews of a Business With No Physical Address - Elfsight Help Center
I think I am stuck in the queue, please help!
ChIJTQLVCaezVogRwmc65-FZZZM
EMBED maps
Hi there, @Pittrader_Info :waving_hand:
Currently, we’re experiencing some technical issues with the review collection. I am genuinely sorry for this inconvenience!
I’ve forwarded your source to the devs and will update you once it’s fixed.
Hi Max, are you able to help me with this same issue? I’m getting the message “No reviews found. Please make sure the source is correct, that it has reviews and that filter settings do not exclude all the reviews.” despite having 29 reviews. Here is my Google Maps link
Hi Max - I’m having the same issue. I’m trying out the Google Reviews widget for the first time, but it won’t collect my reviews either. It finds the Google Maps site without a problem.
Hi Max, I am facing the same issue. source tab says : Oops! We couldn’t collect reviews from the provided source. Please double-check the source and make sure there are reviews there. If the source is correct and you’re still facing issues, reach out to our support team. We’re here to help and will figure out what went wrong.
while review exist and no filter has been applied.
Hello friends!
I deeply apologize for all the inconvenience for this situation!
@user3615, @Rico I’ve forwarded your sources to the devs and will get back to you once they are fixed.
@Harshkumar_Chauhan I see that the reviews showed up in your widget. Could you please check it and let me know if everything is fine now?
hello, im experiencing the same issue of no reviews being found, any estimate on when things will go to normal?
Hi there, @Daniel_Vasquez :waving_hand:
Please accept my deepest apologies for this inconvenience.
The thing is that the issue occurred on the end of our review provider, this is why it’s hard to share the ETA at the moment. However, they are doing their best to address this issue as soon as possible.
Hi @Max
We’re currently experiencing the same issue with our Google Reviews widget created Feb 18, 2026. In the Sources tab, we’re seeing the following message for the Google tab:
However, the Google Business profile we are trying to add definitely has active reviews that should be displayed.
Could you please forward our source to the dev team as well for investigation and a fix? We’d really appreciate it, as Reviews section is an important trust element on our sites.
Thank you in advance for your help!
Thanks for the information, I am experiencing this issue too.
Please keep me updated as it is blocking a couple of important projects.
Kind regards,
Simon.
Hello guys, @Emerge2_Digital, @AxeDigital :waving_hand:
Surely, we’ll keep you posted on any progress here!
We really appreciate your patience and understanding :folded_hands:
Hi @Pittrader_Info, @user33449, @Rico, @Daniel_Vasquez, @AxeDigital :waving_hand:
While the global issue still persists, we’ve managed to manually fix it in your widgets. Please check them out and let us know if they’re fine now.
@Emerge2_Digital Unforunately, the issue with your source still persists. We’ll immediately inform you once it’s fixed.
