Its not really the access to the admin penal. Its more like adding user to the eventcalender. So they could send in their own Events. I get the info, can check it and activate the event.
But no access to all other things like the layout, etc.
To number 2:
If i create the user i link it to a host. So he can only sent in events for this host .
So he can create events only in his name (host)
I hope its understanable now ![]()
I got your point, thanks!
We already have a similar idea in the Wishlist. Iâve added your comments there too, so that you could keep up with the latest updates here.
As for the adding events only for the specific host, I agree that it would be a great option. Weâll try to consider it in our future updates as well ![]()
I totally agree with this. I ended up buying the Elfsight form builder app to help, but still, it doesnât integrate with Calendar app, so there is the manual step of entering the formâs data into calendar.
I do see your point, and I am really sorry that our doesnât support this feature yet. Weâll try to consider this opportunity in the future updates and Iâll make sure to keep you updated ![]()
A huge thank you for your interest and help!
Allow the elfsight form builder to populate a calendar dynamically (a little surprised this isnât already available? Am I missing something?)
If I understood you correctly, youâd like to have an option to submit event via your Form Builder widget and these events should be dynamically added to the Event Calendar widget.
Unfortunately, this option isnât supported now, I am so sorry! We have such a request in the Wishlist, and Iâve moved your comment there too. All the updates will be posted in this thread ![]()
In case I misunderstood you, please share more details on your use case. Iâll gladly look into this for you!
I agree with this request. It would be nice to have an API that takes local form data and adds/edits events to a shared calendar. Iâd just like to see the forms youâve already designed in the elfsight calendar editor in my website - they are perfect. Could these be delivered as part of the widget?
Hi there @snpc ![]()
I totally agree that this feature would be really helpful for many users! Weâll try to work in this direction in our future enhancements, and Iâll keep you updated ![]()
Thanks a lot for helping us grow and welcome to the Community!
Ăa me semble ĂȘtre une Ă©volution nĂ©cessaire pour autoriser uniquement la saisie dâĂ©vĂ©nements par des collaborateurs qui ne doivent pas modifier les paramĂštres mais exclusivement faire de la saisie.
It seems to me to be a necessary development to only authorize the entry of events by collaborators who must not modify the parameters but exclusively do the entry.
Bonjour @CrocTonPlaisir ![]()
Ai-je bien compris que vous souhaitez partager lâaccĂšs Ă votre compte avec les collaborateurs, afin quâils puissent crĂ©er de nouveaux Ă©vĂ©nements dans le widget ? Si câest le cas, vous pouvez le faire en utilisant la fonctionnalitĂ© Membres (disponible Ă partir des forfaits Pro).
Retrouvez plus de dĂ©tails dans cet article - [MAJOR UPDATE]: Introducing the INVITE MEMBERS feature in your Dashboard! âĄ
Cependant, si je vous ai mal compris, veuillez développer votre idée ![]()
Hi there @CrocTonPlaisir ![]()
Do I get it right that youâd like to share access to your account with the collaborators, so that could create new events in the widget? If it is, you can do this using the Members feature (available starting with the Pro plans).
Find more details in this article - [MAJOR UPDATE]: Introducing the INVITE MEMBERS feature in your Dashboard! âĄ
However, if I misunderstood you, please elaborate on your idea ![]()
Bonjour Max, oui câest bien cela : permettre Ă un collaborateur de crĂ©er des Ă©vĂ©nements dans toutefois modifier les paramĂštres.
Je vais regarder le lien.
Merci pour ton retour.
Hello Max and thank you! While the collaboration feature would be great for some instances that is not exactly what I am looking for in the calendar widget. I am an agency that provides sites for organizations. I would be able to use the calendar widget for their sites if THEY (my client) could manage the calendar. I donât want them as a collaborator in my Elfsight account but instead simply as a âcalendar managerâ from the front end of their website. Thanks!
Thank you for your comment, @T111!
You know, weâre on the verge of releasing an option that allows Project users to share access to a specific widget. You can follow the updates here if youâre interested: Provide a client with access to specific widgets within his project ![]()
Thank you Helga ! I am now following the topic ⊠That is exactly what I am looking forâŠ.
Thanks!
~T. Gath
Web: Ed Web Services
Email: admin@edwebservices.com
Agreed. We use the calendar for events in our city and would like to allow readers to submit their events for consideration. It would be so helpful! Thanks!
Community Based calendar entry would be amazing! I would like to have the option to review and approve the entry before it gets published on the shopify store.
Say you have 20 organizations that have regular events, it would be nice to give them their own login limited to register their upcoming events. I would prefer it come to moderator first who will approve it, alternatively do some edits before itâs published. This would save a lot of time for admins to run this event calendar portal.
@MariusP Thanks for the note!
Weâll have it in mind when considering this request ![]()
