Wordpress Plugin to display reviews and manage widget
Would be great to have a wordpress plugin that pulls via API so not using JS to embed so better for SEO.
Also would be great to be able to collect review on wordpress site and stored in DB so people can leave reviews for website within wordpress and not have to manually add them… but let them submit as well.
Maybe even add a source option for Wordpress / Feed URL so could use / make another plugin to collect reviews for site visitors and can then load via a RSS feed URL or something… a quicker option would be able to load customer feed urls for sure!
Checkatrade service only allows manually adding reviews, would be good to auto collect reviews via API (if available, not sure if one exists) but could use a web Extractor / scrapper to achive this.
Hi there @James_Brandon :wave:
If I got you right, you’d like to have a source option to automatically collect WordPress reviews.
If it is, could you please send me a link to your WordPress reviews for a reference?
Yes that would be 1 thing, i dont have a review addon in place on wordpress for current site working on currently so if can recommend one would be great but overall would like to allow site visitors to be able to lave a review from the reviews widget using a button to post a review under the website tab when opened…
I guess would just need to ability to fetch reviews from local wordpress database reviews table or something to pull through but able to set a leave review action button to allow them to leave a review from the widget if makes sense?
Got you, thanks for sharing the details!
If more users support this request, we’ll try to think it over in the future updates :slightly_smiling_face:
