Reviews widget for avis-verifies.com
Same functionalities that the Google widget reviews and to be able to switch from Google reviews to this one.
Hi there, @Cathy_FORD :wave:
Thank you so much for the idea! If this source gains more votes, it might be considered in the future :slightly_smiling_face:
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
