Viator reviews
Viator reviews
Original Votes: 2
Wow…this feature should be implemented immediately, using your product is useless to me until Viator reviews is implemented.
Hey @Peter_Canada, great to see you on the forum! :wave:t2:
I know, Viator reviews would be a great addition to the widget, but I’m afraid that at the moment, we don’t see a quick solution for its implementation, I’m really sorry :frowning:
But, we’re on the verge of adding an option that will allow you to add reviews manually, regardless of the source. Perhaps it could work as a workaround :slight_smile:
Just in case, we post updates for this feature request here: Be able to manually add reviews to the All-In-One-Reviews + premoderation.
Repuso.com has found a way to do it I think?
Good point, Peter! The thing is that methods might differ, and it seems that is the case here. We don’t know how exactly Repuso implemented Viator reviews, but I’ve shared your question with the team :slight_smile:
I’ll make sure to post an update here if I have any news!
Trustindex io is gathering reviews from Viator and GetYourGuide too. Your widget is unfortunately useless for tour operators, as it’s too much work to upload reviews by hand. I like the widget in general but these are just BASIC needs for the tourism industry.
Hi @user8590 :wave:
Many thanks for your comment!
I do see your point, and I’m very sorry that our widget doesn’t support this feature. We’ll try to consider implementation of the Viator source in the future. All the updates will be posted here :slightly_smiling_face:
May i request for a viator reviews widget please
Greetings and welcome to the Community @Aamin_Hussain :wave:
We already have a request for the Viator source in the Wishlist. I’ve moved your comment to the related thread where we’ll post all the updates :slightly_smiling_face:
As a workaround, you can use a Custom Source option in our All-in-One Reviews app and add the needed reviews manually. Feel free to check it out:
I have over 500 reviews on Viator. i think I will wait
You really need to expedite this feature!
Hi @Peter_Canada :wave:
Thank you so much for pointing us in this direction!
I totally understand your point and hope that devs will consider implementation of the Viator source in the future updates.
I’ll make sure to update you here in case of any news :slightly_smiling_face:
Thanks
+1 We need Viator
Hi @Samuel_Gonzalez :wave:
Thanks for your interest and help!
Once we receive any news about the Viator source, we’ll immediately update you here :slightly_smiling_face:
Yes, please find a way to add Viator. It’s so important.
Hi there and welcome aboard @user13405 :wave:
Thanks for adding your idea to the Wishlist!
We see that this source is quite popular among our users and we’ll have it in mind for the future updates.
We’ll keep you in the loop :slightly_smiling_face:
+1 we need viator
Hello,
I also have more than 130 reviews in Viator! It would be great if you can add it!
Thanks in advance :slight_smile:
