Using different Instagram Accounts for different websites
I’m looking at upgrading my account so that I can use an Instagram widget across a few different websites. Whilst these websites are similar, they are focussing on a different niche and ideally, we will be able to create different Instagram channels for each niche and add these Instagram feeds to each specific website. Does anyone know if this is possible using this widget?
Hi there and welcome to the Community, @Interact_IT :wave:
You’d like to use a single Instagram Feed widget with the flexibility to specify different sources depending on the webpage where it is placed, right?
If you are going to use your widget on pages within one website, the dynamic source option should work for you.
This feature is available only for Enterprise customers. If you’d like to learn more detail, please contact Elfsight Support Team .
However, if you are going to use it on pages of different websites, the only solution is to create a separate Instagram Feed widget for each website.
Let me know if you have any questions left :slightly_smiling_face:
Hi Max, thanks for getting back to me. I’m not sure if your solution would work. I may have not explained the situation properly, in which case I apologise.
Basically, we have two websites where we would like to display different Instagram account posts on each website. So website 1 would display posts from instagram.com / account1, whilst website 2 would display posts from instagram.com / account2
Is this possible with just one account on elfsight? Or would you need separate elfsight accounts in order to connect different Instagram accounts? Hope I have explained it ok
Got it, thanks for clearing that up!
You don’t need separate Elfsight accounts for this.
Right now, with the Free plan, you can only create one Instagram Feed widget. However, if you upgrade, for example, to the Instagram Feed Basic plan, you’ll be able to make up to 3 widgets, set different sources, and use them on different websites.
I’m happy to offer you a 20% discount on our yearly plans. Just use the coupon code 4B15C4CD to upgrade your subscription.
Here’s what you’ll get with the upgrade:
  • Faster support for installation and customization
  • Higher view limit
  • More widgets
  • Ad-free experience without the Elfsight logo
Plus, with our 14-day money-back guarantee, there’s no risk: you can cancel anytime if it doesn’t meet your needs.
If you have any questions left, I’ll be happy to answer them :slightly_smiling_face:
By the way, we’d like to invite you to join our new challenge. This time, you should create a slogan for Elfsight to win a 6-month extension to your subscription.
Check the details and join in: October Challenge: Create Slogan for Elfsight and Win 6 Free Months! (+2 weeks guaranteed)
We’ll be super happy to see you as a participant :wink:
