I have multiple review widgets, each assigned to different products we offer. I’d like a single review widget that aggregates all reviews, from all sources, into a single review.
Right now I do this manually, by re-linking all my sources, but it’s time consuming and error-prone.
Do I understand correctly that you mean a summary that should be automatically generated (the same as the AI Generated summary in our standalone Reviews apps)?
If you look at the widget I’m using right now on my homepage, you’ll see that I’ve added 20+ sources to create a “summary” widget that aggregates my reviews across all widgets: https://basecampstays.com/
Right now, for each property, I create a standalone widget and link 2 sources (airbnb and vrbo). That way I have a review widget for just that property. Then… I have to create this company-wide summary widget that I’ve shown in the link above, by manually re-linking all these sources for each property.
