To make a popup when users click this See Bio link.
#1. First, create a Meet Our Team Lightbox page (in Not Linked) then edit it.
#2. Click Add Block
#3. Choose Text Block
#4. Enter your desired text
#5. Next, find ID of Text Block
#6. Edit Meet The Team page (page where you use See bio link)
#7. Edit text See Bio > Add a link
#8. Enter this link format:
#wm-popup=/meet-our-team-lightbox#enter-text-block-id
for example
#wm-popup=/meet-our-team-lightbox#block-yui_3_17_2_1_1753743047176_3819
Make sure Open link in New Tab is disabled
#9. Install WM Popup Plugin
Plugin will give you some code to add to Code Injection Header/Footer, like this.
#10. Result
#11. Repeat same steps for other items
