To make small text popup on button click, like this.
#1. First, add a Page in Not Linked with Name: Popup Text – URL /popup-text
#2. Add 2 Text Blocks, then find IDs
#3. Next, edit 2 Buttons > Use this URL
#wm-popup=/popup-text#block-yui_3_17_2_1_1754201703787_13803
#wm-popup=/popup-text#block-ff83879569ff1b2f32b2
Repeat similar if you have other buttons, url format is:
#wm-popup=/popup-text#enter-text-block-id
Plugin will give you some code to add to Code Injection > Header.
and Footer
#5. Result
