(Squarespace) Click text in Paragraph - Open Text Popup
To make Popup appears when users click on a text in Paragraph, you can follow these.
#1. First, create some pages in Not Linked (Popup will pull content from these pages)
Page 1:
  • Bio 01 – /bio01
Page 2:
  • Bio 02 – /bio02
Page 3:
  • Bio 03 – /bio03
#2. Highlight text in Paragraph > Insert URL > Use this format. Make sure “Open in New Tab” is disabled
#wm-popup=/bio01
#wm-popup=/bio02
#wm-popup=/bio03
You will have 3 text.
#3. Install Popup Plugin
and Footer
#4. Result
When you click text: scientists or expresso or obsessed, Popup will appear.
