To make Form Popup appear when users click text in a paragraph Squarespace, you can follow these.
#1. First, create a Page in Not Linked.
With Name/URL: Content Lightbox – /content-lightbox
#2 . Edit Content Lightbox page > Add 3 Form Blocks > Then find ID of 3 Form
In my example, we will have:
- Form 1: #block-yui_3_17_2_1_1740194891538_7640
- Form 2: #block-da4d2bf8093364e61571
- Form 3: #block-da08004027c8ede46324
#3. Edit Paragraph where you want to make Form Popup appear > Edit 3 Texts > Add URL > Use this URL format.
Text 1: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740194891538_7640
Make sure “Open in New Tab” is disabled
Text 2: #wm-popup=/content-lightbox#block-da4d2bf8093364e61571
Text 3: #wm-popup=/content-lightbox#block-da08004027c8ede46324
#4. Install Popup Plugin
and Footer
#5. Result
When users click text 1 >> Form Popup 1 will appear
When users click text 2 >> Form Popup 2 will appear
When users click text 3 >> Form Popup 3 will appear
