(Squarespace) Click text in paragraph open Button Popup
To make Button Popup appear when users click text in a paragraph, you can follow these.
#1. First, create a Page in Not Linked.
With Name/URL: Content Lightbox – /content-lightbox
#2 . Edit Content Lightbox page > Add 3 Button Blocks > Then find ID of 3 Button
In my example, we will have:
  • Button 1: #block-yui_3_17_2_1_1740272913615_79669
  • Button 2: #block-c79f90e467e0372127e6
  • Button 3: #block-61053b72b5a0c77f44e1
#3. Edit Paragraph where you want to make Button Popup appear > Edit 3 Texts > Add URL > Use this URL format.
Make sure “Open in New Tab” is disabled
Text 1: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740272913615_79669
Text 2: #wm-popup=/content-lightbox#block-c79f90e467e0372127e6
Text 3: #wm-popup=/content-lightbox#block-61053b72b5a0c77f44e1
#4. Install Popup Plugin
and Footer
#5. Result
When users click text 1 >> Button Popup 1 will appear
When users click text 2 >> Button Popup 2 will appear
When users click text 3 >> Button Popup 3 will appear
@tuanphan,
:heart: :heart: :heart:
