(Squarespace) Click Image - Open Popup with Text
To make Text Block Popup appear when users click an Image, you can follow these.
#1. First, create a Page in Not Linked.
With Name/URL: Content Lightbox – /content-lightbox
#2 . Edit Content Lightbox page > Add 3 Text Blocks > Then find ID of 3 Text Blocks
In my example, we will have:
Text Block 1: #block-yui_3_17_2_1_1740272913615_165947
Text Block 2: #block-6e0b1662d4ce74610392
Text Block 3: #block-dedf2912794f940fe94f
#3. Edit Images where you want to make Text Block Popup appear > Edit 3 Images > Add URL > Use this URL format.
Make sure β€œOpen in New Tab” is disabled
Image 1: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740272913615_165947
Image 2: #wm-popup=/content-lightbox#block-6e0b1662d4ce74610392
Image 3: #wm-popup=/content-lightbox#block-dedf2912794f940fe94f
#4. Install Popup Plugin
and Footer
#5. Result
When users click image 1 >> Text Block Popup 1 will appear
When users click image 2 >> Text Block Popup 2 will appear
When users click image 3 >> Text Block Popup 3 will appear
@tuanphan,
:heart: :heart: :heart:
