You need to keep the Network tab opened and click on the Builder tab:
Have you tried it yet?
Thanks yes I understand, the image above with the pop up on the left. With the builder button, I cant click on this, it is just an Image. It doesnt work nothing happens when I click on it in the ’Inspect’ screen. im really sorry about this could i just give you my password to try?
Hi Max, Just to update you I tried to get the smtp working on another device but had no luck there. However I am quite happy that the subscriber email is landing in the inbox now, and not spam and it all looks okay anyway with my business name. Thanks for all you help, I appreciate you being so patient. Gráinne
Hi there, @Grainne1 ![]()
I’ve discussed the issue with the devs once again and it appears there was some kind of miscommunication. I am so sorry!
In the password field, you should use a generated app password, but not a password from your Yahoo account. This article explains how you can get it - Generate and manage 3rd-party app passwords | Yahoo Help.
Please give it a try and let me know if it worked ![]()
