LinkedIn Feed Issue
I’ve tested it and it seems to work but when I click on "Embed the widget on your website, the code do not appear and a grey loader turns forever without displaying the code once registered to my account
Hi Eric! Oh, I’m really sorry, we’ll look into this for you to see what went wrong. We’ll get back to you once there is any news :pray:t2:
I had the same problem when I use the dark design. Background and text went white.
I used the light Design with gray background and shadow and its looks like perfectly
Hello guys @The_Algar @user3154 :wave:
Could you please send us a screenshot or a video screencast of the issue.
It would be tremendously helpful!
You can only set the dark mode and then use the code and the problem should be visible.
At the moment I am unfortunately elsewhere in use, if it does not work I can make the attempt next weekend …
Hi Max
did you received my screen shots?
Any idea what’s going on?
Please advise
Hi @The_Algar :wave:
Unfortunately, I haven’t received your screenshots.
Could you please attach them in this topic?
However, if you could send us a video screencast of the issue instead of the screenshots, it would be really helpful. The screencast will give us a better understanding of what’s going on.
Hi Max
Video screen cast here you go!The last bit turns forever without any change
Please advise
(Attachment Screen_recording-2023-06-30_14-08-05.mp4 is missing)
this si what happens when I try to send you a screencast
Unfortunately some attachments in your email message to [“incoming+6f7cd746733eef72a47a1965caf71a26@elfsight.discoursemail.com”] (titled Re: [Elfsight Community] [Get Help/General Questions] LinkedIn Feed Issue) were rejected.
Details:
Screen_recording-2023-06-30_14-08-05.mp4: Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, heic, heif, webp, avif).
If you believe this is an error, contact a staff member.
how can I send you the screencast?
I am so sorry about the inconvenience!
I’ve contacted you directly at your email address. You can try to attach the screencast in your reply.
Please check your inbox.
Looking forward to your reply!
