LinkedIn Feed Image display issue
Hi Helga
LinkedIn Widget is running well, i just buyed pro version.
I have only noticed one problem, from a certain (first feed: from fourth post, second feed: third post) post the post image is no longer displayed (see picture, attention two feeds)
Maybe I can set this somewhere ?
Regards
MarcelG
Hi @Marcel_Gay and welcome to Community :wave:
Please let me step in for Helga.
I’ve informed our dev team about this issue. I’ll keep you posted here!
Hi Max
The probleme described before is still present.
Find you a solution ?
Regards
@Marcel_Gay I am genuinely sorry for keeping you waiting!
The issue appeared to be more complicated than it expected to be. Our devs are doing all their best to release a fix as soon as possible.
Rest assured, we’ll keep you in the loop regarding any updates or changes.
Thank you for your patience and understanding :pray:
I found out that no graphics/image is displayed if the post does not contain an image but a PDF, video or something other than an image
Thanks for sharing this insight!
Could you please send me an example of such an issue?
We’ll be happy to look into this as well :slightly_smiling_face:
Hi @Marcel_Gay
Please accept our sincere apology for the delayed reply!
We’ve fixed the issue with and the preview images of the links are displayed now.
Energiecontrol widget displays all the preview images. As for the Proton Automatiom GmBH, you need to enable external links to display preview images:
Please check it and let me know how it worked :slightly_smiling_face:
Hi Max! I have now tried the LinkedIn widget and I have some issues with images showing when I add the widget to our website.
In Elfsight it looks good but on our website no images are showing.
I’ve read the answers above but I cannot get it to work. Do you have any suggestions?
I have images but I could not add them here.
Kind regards Lina//
Hi @Bengt :wave:
Could you please send me a direct link to the page where your widget is installed?
Hi Max!
The widget is at the bottom of this page STC Research Centre | miun.se
Lina//
Thanks a lot!
To fix the issue, we need some additional info, that’s why I’ll contact you directly.
