Issue with the LinkedIn Feed widget
Was this fixed? I can’t connect it or post it to LinkedIn either. I’m a paying member, just got it today.
Happy to see you’ve decided to join our Community @Imani_Hicks :wave:
Could you please send me a direct link to the page where your widget is installed, or specify the widget ID?
I’ll be happy to investigate it for you :slightly_smiling_face:
I can’t install it. LinkedIn won’t let me paste the url and they don’t do embedded codes
Unfortunately, there is no option to install widgets to LinkedIn using embedded codes, I am really sorry!
If I understand correctly, you’ve also tried to add a widget share link to your LinkedIn post, but it didn’t work. If it is, could you please send me a screenshot of the issue?
I used a copy link not a code. th link works on facebook
@Imani_Hicks Unfortunately the image is not displayed on my end:
Could you please try to attach it once again?
