Issue: Login with Google (Comment Widget) 👀
Hello, Elfsighters! :waving_hand:
I found a glitch in the comment widget, you cant login with google. :frowning:
This is the error massage i get if i click on the login button.
Thanks :slight_smile:
I am not having problem with google login, instead I have a problem when I add comments.The comments and name of user is not shown
I think you have deleted the comment widget from your elfsight dashboard. So,maybe its happening
Hey @maxim!
Oh, this is really unfortunate. Can you please send me the link to the widget in question? Also, can you send a screenshot of the developer console at the moment you’re trying to sign up? It might be helpful :slight_smile:
@Nadiashahid1 we’ll get back to you in a separate topic you’ve opened :slight_smile:
Hi @maxim :waving_hand:
Thanks for bringing this to our attention!
We’ve managed to replicate the issue, and I’ve forwarded it to the devs. I’ll get back to you once I have any news :slightly_smiling_face:
Here you go! :slight_smile:
Thanks! :smiley:
Our devs are still investigating the issue. I’ll update you once I hear back from them :slightly_smiling_face:
Alright! Let me know if they have news! :slight_smile:
Console:
Directly after “Login with google”! :sweat_smile:
We need a fix :slight_smile:
And this too:
Thank you so much, @maxim!
We are still investigating the issue, I’ll keep you updated :slightly_smiling_face:
No problem! :slight_smile:
Any updates? :slight_smile:
Unfortunately, we haven’t got any news yet :pensive_face:
Our devs are still investigating the issue. Hopefully, they’ll be able to find a solution soon and I’ll make sure to update you here in case of any changes!
Okay! Thank you! :slight_smile:
Any Updates?
Hi there, @maxim :waving_hand:
The issue has just been fixed and everything should be working fine now. Could you please check it?
It works, thank you so much! :slight_smile:
Great, you’re always welcome :wink:
Hey! :blush:
Just wondering, do I get the Bug Reporter badge for reporting this issue?
Thanks! :slight_smile:
