Hi. I’m relatively new here. I’m a voice over artist, and I’m using one of the audio player widgets on my website. If I had a question it would be, ‘can I use the same widget twice on the same website?’ I recently discovered that the widget can be “copied,” and I’d love to be able to create an additional demo playlist, if that is possible. ~LCDVoice
Happy to see you’ve decided to join us! Welcome, @Lemuel_C_Dees
Sure, you can install the same widget on different pages of your website. If needed, you can even add it multiple times to the same page.
I noticed that you haven’t modified the content or settings of your copied widget, so it’s identical to the original one.
Just to clarify, you don’t need to create a new widget for each website or page if you want to display the same version everywhere. A single widget can be installed on as many different websites as you need.
If you have any questions left, we’re always here to help
Thanks for responding so quickly! Yes, I started to work on the next widget, but thought I should check just to be sure. (I didn’t want any sudden unexpected charges to show up). Thanks for the information!
