Issue description:
I have designed a comments widget and have placed it 4 times on the same page. However it only shows on the first instance of the HTML code. Is there a limitation that I can only have one widget displayed per page?
Hi there, @Daniel_Howden and welcome to the Community ![]()
I’ve just checked your website and see only 1 instance of the widget’s installation code there:
If you’d like to add several instances of the same widget to the same page and need help with it, please request the installation in your dashboard. Our Support Team will be happy to assist you with it ![]()
