Question about payment plan widgets
  • Issue description:
hi. I am currently subscribed to the £ 12-a-month deal. I have just changed the plan (again lol) to use the comments widget on my website. Heres probably the simplest of questions asked lol…….1/9 mean that i can place widget on 9 pages/sites? Or 9 lots of comments?
Hey @jellybaby80 ,
This means you can create 9 separate widgets of “Comments” so you can create two different “Comments” widgets maybe one can be for “Feedback” & the other one can be for “Reactions”.
You can also place 1 widget into 9 different pages or websites and it will still only count as “1” widget because you are only using the one you created, not multiple. Until you create more “Comments” widgets it will also say “1”
To test if this is true you can comment on the widget 9 times or put it on 9 pages/sites and it will still say 1.
@jellybaby80
I’d also like to add that you can place the “Comments” widget on multiple pages/sites and it will still be “1” widget but also remember that it will create more views so if you have a lot of traffic it may not be a good idea to put it everywhere because it may hit the “50,000 Views limit” but you likely know your website traffic and can plan accordingly.
Here is a screenshot of the plan details for accuracy of what I’ve said thus far:
Hi there, @jellybaby80 :waving_hand:
Adore is absolutely right! If you still have any questions left, we’ll be happy to advise :wink:
@Adore, thank you so much for your prompt help :blush:
