Everything was working fine for weeks and now the images are no longer visible. Overlays on hover etc. are still there, but the images are all white. https://maschinenfahrer24.at/
Any ideas?
Thanks,
Max
Any ideas?
Thanks,
Max
Hi Max and welcome to the forum!
I’m so sorry to hear that you’re experiencing issues with our Social Feed widget, and I’ll try my best to help!
I’ve checked your website and I do see the issue you described. I’ve also checked your account and I see no problems with it, so it should be working correctly.
Could you please try to disconnect your widget and then connect? It could help bring the widget back again.
Please let me know if it worked.
Hi Helga,
That did not help sadly…
Sorry i just realised it did infact work!
That’s awesome, thanks for the update, Max!
I hope no issues will ever come for you, and I wish you just a great user experience ![]()
