Have you get problem with Etsy review widget not working?
I have try to Edit my Etsy review for my website but there have issue and have a message :
We’re currently doing some technical updates. Your reviews are in line to be collected. Once we’re done, they’ll appear in your widget. For now, you can save your widget and come back later to see the reviews.
have you get same case with mine ?
Thank you
Welcome to the Community, @Verdant_Wijaya :waving_hand:
I’ve forwarded it to the devs and will update you once it’s fixed :slightly_smiling_face:
Hello Max, Thank you for your help, and please let me know when they already have fixed it.
Thank you again.
Kind regards
Verdant
Sure, I’ll keep you updated :slightly_smiling_face:
Hi there, @Verdant_Wijaya :waving_hand:
The issue has been resolved. Please check your widget and let me know if everything is fine now :slightly_smiling_face:
