Widget Not Connecting to URL
Hello, I have been trying to connect my Etsy reviews for over a month now, and I keep getting:
“We’re currently doing some technical updates. Your reviews are in line to be collected. Once we’re done, they’ll appear in your widget. For now, you can save your widget and come back later to see the reviews.”
I’ve kept checking back in, deleting the widget and trying again, but nothing. Is there anything I can do to fix this? Much help would be appreciated. Thank you.
Hi there and welcome to the Community, @user29307 :waving_hand:
I am so sorry for all the inconvenience!
I’ve passed this issue on to the devs and will update you once I have any news :slightly_smiling_face:
The issue has just been fixed!
Please check your widget and let me know if everything is fine now :wink:
