"We're currently doing some technical updates."
Attempting to create an Etsy Review Widget, but when I plug in my etsy link, im getting this error message: We’re currently doing some technical updates. Your reviews are in line to be collected. Once we’re done, they’ll appear in your widget. For now, you can save your widget and come back later to see the reviews.
I let this sit for a week before coming back and seeing the message still there. I deleted the widget, attempted again, same message.
This error message does not happen when I plug in my other etsy shop link.
Happy to see you in our Community @Luminous_Senecio :waving_hand:
The issue has been resolved, and the reviews are displayed in your widget now:
If any further help is needed, we’re always here for you :wink:
Hi, I’m having the same issue with the All-in-one reviews over the last couple ofdays - but only with reviews from vrbo. I’ve tried reconnecting the URL. Do I need to just wait or have I missed something?
Hi there and welcome to the Community, @Victoria_Davies :waving_hand:
I’ve shared this issue with the devs and will update you once it’s fixed :slightly_smiling_face:
Hi Max, I’m not sure if you can help. My All-in-one reviews app still isn’t importing reviews from Vrbo. When I click on the help button nothing happens! The red error message is not longer showing on the All-in-on portal but the reviews still aren’t pulling through.
I have another couple of apps I would like to add but I want to make sure this one is working before I buy a bundle.
Many thanks
Vicky
Hi there, @Victoria_Davies :waving_hand:
Our devs are investigating the issue and they’ll try to fix it as soon as possible. I’ll keep you updated!
Thank you for your patience and udnerstanding :folded_hands:
Hi @Victoria_Davies :waving_hand:
I am truly sorry for the delayed response!
The issue is finally fixed. Please check your widget and let me know if the reviews have been collected :slightly_smiling_face:
