Widget etsy rating
Hello, it’s been 8 days since the Etsy widget cache has not worked?
@user661 hi and my apologies for the delay!
I’ve checked your widget, and it seems it works correctly and all the reviews are displayed fine now. Could you please double-check?
If the issue still persists, please send me a link to the page with the widget in question, a screenshot of how you see the widget, and name the device and browser you use. I’ll be happy to check things for you :slight_smile:
