Formula for my Pricing Calculator
Hi I would absolutely love some help working out my formula for my pricing widget. Sorry Its my first time using this and the formula part is very overwhelming.
Thanks
Rob
How far have you got in setting it up, can you send the URL link, so I can see what you’re trying to calculate.
Hi Darryl
Thanks for replying
I haven’t got very far if i’m honest - it’s getting rather frustrating to say the least!
It has quite a few logic conditions so it’s getting way above my head.
Here’s the URL.
[https://5e569bd68e064d69915c8e7ab1452836.elf.site](https://5e569bd68e064d69915c8e7ab1452836.elf.site)
Thanks for your time. Do you think you’re able to help?
Cheers
Rob
Yes, for starters, I would advise having individual lines of calculations for the individual services and then you can easily make a calculation via adding the individual services to the total calculation, check out my calculator as an example here: https://c9625df209ab45ee9dcf038d74d5148b.elf.site/
Hi there, @Rob_Godson and welcome to the Community :waving_hand:
Could you please describe your use case in more detail and describe how the formula should work? We’ll be happy to adjust it for you :slightly_smiling_face:
Ive made the calculator alot simpler… any chance you could help me fix up the formula for it please? Thanks
Thanks for sharing a link to a new calculator!
You’d like to calculate the total cost for all chosen services, right? If so, could you please describe how the total cost should be counted in your case?
Sorry not sure what you mean exactly. Can you see all the drop down menus?
Yes, I see the dropdowns in your calculator, but you haven’t added any calculation:
To help you adjust your formula, we need to know how the price should be calculated in your specific use case. Is it just the sum of all services, or it should work differently?
Any additional details would be much appreciated :folded_hands:
Oh thank you i understand now. Sorry my bad.
Yes so …
The customer selects which package they would like (first drop down under select services). The choice is real estate package, airbnb and individual services.
Pathway 1: Real estate → Studio Prime
Studio Plus
Studio Pro
Studio Platinum
Choose with real estate package tier they would like then add up all the services which follow.
Pathway 2:airbnb → Studio bronze
Studio silver
Studio gold
Studio Diamond
Choose with airbnb package tier they would like then add up all the services which follow.
Pathway 3: Individual services. This skips the tier drop down box and just choose from all the other services.
Hopefully that makes sense :slight_smile:
Thanks for your help.
Rob
Yes so …
Studio Plus
Studio Pro
Studio Platinum
Studio silver
Studio gold
Studio Diamond
Rob
It’s difficult to formulate your calculator, unless I have full access to it to get you started.
I’ll copy in @Max to see if this is possible. Or if you’re ok, you can change your login password and supply me with your login name & temporary password to your account? you can email me directly rather than making it public info@darrylrixonphotography.co.uk
I’ve forwarded it to the devs and will let you know once the formula is ready :slightly_smiling_face:
Oh wow thank you so much. Really appreciate the help!
Hi there, @Rob_Godson :waving_hand:
To set this up, all dropdowns should have a default option with a 0 value (The Default option in some of them is currently set to None). The only exception is dropdowns where all options already have a zero value (like the field shown in your screenshot)
For example, you can add an option like “Not selected” with a value of 0 and set it as the default for the dropdown:
Once that’s done, you can use the following formula:
SUM({{155e11f4-d396-4ff9-be1c-e306f2120379}}, {{0b4850a7-8c68-4823-bfdd-c30112fee8f3}}, {{2de3b14f-9ced-4f83-b2f0-4be1736e16a5}}, {{397d8c30-1792-4b9e-88d4-c328dfc4665b}}, {{8f86605a-c30f-44fa-b038-5eed0fac9094}}, {{003debf2-7187-42e0-b165-4ab9a4b4dcad}}, {{15826296-7017-41dc-85e9-15a240eaab7a}}, {{5256d5e6-0936-443f-a463-94a67a6b1e45}}, {{b2317eb9-d06d-428b-9b9b-1290b9ec0f94}}, {{08ddc958-c7f7-44de-9b1e-d1567e5acf6c}}, {{8069ddb0-dd1b-4b14-97ef-1eab340e7a16}}, {{4b80ae1c-681f-42dc-bf03-db54f250304c}}, {{94029bdf-90e0-44da-94c4-af0fff57a740}}, {{b50e94f6-3544-4fd3-b118-bfbb68ae4706}}, {{8e8fc018-dd1b-4af7-8615-e05a0a7e6e2b}}, {{f25f34a5-ac19-445c-a886-42ed532993bc}}, {{7ef7a1a0-e317-4413-be0d-55a54b576be1}}, {{c0829ec7-4772-4216-a158-b6b3278bd1af}}, {{1678332e-69ee-441a-85e1-1bec8802bec3}}, {{1c4266c0-8b69-4e99-8694-d5d9275f110f}}, {{a7b88f57-9563-414e-9cdd-e558dc36a5f3}})
Please try it out and let me know if it worked :slightly_smiling_face:
You’re always welcome!
By the way, we’d like to invite you to participate in our Christmas Giveaway, where you can win a 3-month extension for your subscription - Christmas Giveaway: Win 3 FREE Months (10 winners) + 1 month guaranteed! :wrapped_gift:
