Some instructions to add Calculator to Squarespace with Code Block, they will sync with style from Site Styles.
You can also use Calculator Widget Tool (free) to add Calculator if you don’t want to use complex code.
Style 01. Shipping Rates Calculator
- view demo – password: abc
#1. Install Code
This is just a calculator using a sample formula, but you can easily send it to AI (ChatGPT or Claude. I recommend this AI chat bot, it is designed for Squarespace site) to customize it to your specific needs – and, notably, it can sync with style from Site Styles. You can also use this free calculator tool to create a calculator.
#1.1. You can edit Page where you want to place Calculator > Add a Code Block
#1.2. Add this code into Code Block
<!-- 09.26c01v1 Shipping Rates Calculator -->
<div class="tp-calc" data-tp-calc></div>
window.ShippingCalcConfig = {
text: {
title: "Shipping Rates Calculator",
weightLabel: "Weight",
weightUnit: "lbs",
weightHint: "Select the weight of the package.",
distanceLabel: "Distance",
distanceUnit: "miles",
distanceHint: "Set the distance to the destination.",
serviceLabel: "Service Type",
serviceHint: "Choose a shipping service.",
costHeading: "Shipping Cost",
costHint: "Final Shipping Cost",
etaLabel: "Estimated Delivery Time",
etaHint: "Delivery Time Estimate",
etaUnit: "days",
ctaHeading: "Get Your Package Moving!",
ctaHint: "Experience fast and reliable shipping with our service. Take the next step now!",
ctaButton: "Ship Now",
ctaHref: "#"
tags: {
// HTML tag per text; style (size/color) inherits from the tag on the site
title: "h2",
weightLabel: "h3",
distanceLabel: "h3",
serviceLabel: "h3",
costHeading: "h3",
etaLabel: "h3",
ctaHeading: "h3"
colors: {
// "" = inherit from the tag/class; set a value to override
title: "",
label: "",
smallText: "",
cardBg: "#000000",
cardHeading: "#ffffff",
cardValue: "#ffffff",
cardMuted: "rgba(255,255,255,0.7)"
slider: {
trackFill: "#111111",
trackEmpty: "#eaeaea",
thumbBg: "#ffffff",
thumbBorder: "#cccccc",
trackHeight: "12px",
thumbSize: "26px"
layout: {
valueInputWidth: "72px" // width of the Weight/Distance number inputs
button: {
// "" = inherit the native button classes; set a value to override
text: "",
bg: "",
border: "",
hoverText: "",
hoverBg: "",
hoverBorder: ""
ranges: {
weight: { min: 1, max: 100, step: 1, value: 5 },
distance: { min: 1, max: 3000, step: 1, value: 500 }
formula: {
currencySymbol: "$",
moneyDecimals: 2,
baseFee: 0,
rateByService: { 1: 0.05, 2: 0.10, 3: 0.20 },
milesPerDayByService: { 1: 500, 2: 250, 3: 100 },
// Optional. Return a number; leave null to use the built-in formula.
// costFn(weight, distance, service, formula) -> cost
// daysFn(weight, distance, service, formula) -> days
costFn: null,
daysFn: null
services: [
{ value: 1, label: "Standard" },
{ value: 2, label: "Express" },
{ value: 3, label: "Overnight" }
(function () {
var CFG = window.ShippingCalcConfig;
var CSS =
".tp-calc,.tp-calc *{box-sizing:border-box}" +
".tp-calc{--tp-card-bg:#000;--tp-track-fill:#111;--tp-track-empty:#eaeaea;--tp-thumb-bg:#fff;--tp-thumb-border:#ccc;--tp-track-h:12px;--tp-thumb-size:26px;--tp-input-w:72px;--tp-pill-min-width:84px;--tp-card-radius:22px;color:inherit}" +
".tp-calc__wrap{max-width:1180px;margin:40px auto;padding:0 24px;display:grid;grid-template-columns:1.1fr 0.9fr;gap:48px;align-items:start}" +
".tp-calc__h{margin:0}" +
".tp-calc__title{margin:0 0 32px}" +
".tp-calc__field{padding:6px 0}" +
".tp-calc__labelRow{display:flex;align-items:center;justify-content:space-between;gap:16px;margin-bottom:18px}" +
".tp-calc__sm{margin:14px 0 0}" +
".tp-calc__pill{min-width:var(--tp-pill-min-width);background:#fff;border:1px solid #dcdcdc;border-radius:12px;padding:12px 16px;display:inline-flex;gap:5px;align-items:center;justify-content:center;font-weight:600;font-size:17px;color:#111}" +
".tp-calc__num{width:var(--tp-input-w);border:0;background:transparent;padding:0;margin:0;font:inherit;color:inherit;text-align:right;-moz-appearance:textfield;appearance:textfield}" +
".tp-calc__num::-webkit-outer-spin-button,.tp-calc__num::-webkit-inner-spin-button{-webkit-appearance:none;margin:0}" +
".tp-calc__range{width:100%;-webkit-appearance:none;appearance:none;height:var(--tp-track-h);border-radius:999px;margin:4px 0 0;cursor:pointer;background:linear-gradient(90deg,var(--tp-track-fill) 0%,var(--tp-track-fill) var(--tp-fill,0%),var(--tp-track-empty) var(--tp-fill,0%),var(--tp-track-empty) 100%)}" +
".tp-calc__range::-webkit-slider-thumb{-webkit-appearance:none;appearance:none;width:var(--tp-thumb-size);height:var(--tp-thumb-size);border-radius:50%;background:var(--tp-thumb-bg);border:1px solid var(--tp-thumb-border);box-shadow:0 1px 3px rgba(0,0,0,.2);cursor:pointer}" +
".tp-calc__range::-moz-range-thumb{width:var(--tp-thumb-size);height:var(--tp-thumb-size);border-radius:50%;background:var(--tp-thumb-bg);border:1px solid var(--tp-thumb-border);cursor:pointer}" +
".tp-calc__minmax{display:flex;justify-content:space-between;margin-top:12px}" +
".tp-calc__divider{height:1px;background:#ededed;margin:30px 0}" +
".tp-calc__dd{position:relative;margin-top:16px}" +
".tp-calc__ddBtn{width:100%;display:flex;align-items:center;justify-content:space-between;padding:18px 20px;border:1px solid #dcdcdc;border-radius:12px;background:#fff;font-family:inherit;font-size:17px;font-weight:500;color:#111;cursor:pointer;text-align:left}" +
".tp-calc__chev{width:0;height:0;border-left:6px solid transparent;border-right:6px solid transparent;border-top:7px solid #222;transition:transform .18s ease;flex:none}" +
".tp-calc__dd.is-open .tp-calc__chev{transform:rotate(180deg)}" +
".tp-calc__ddList{list-style:none;margin:6px 0 0;padding:6px;position:absolute;left:0;right:0;top:100%;z-index:20;background:#fff;border:1px solid #dcdcdc;border-radius:12px;box-shadow:0 10px 30px rgba(0,0,0,.12)}" +
".tp-calc__ddList[hidden]{display:none}" +
".tp-calc__ddOpt{padding:14px 16px;border-radius:8px;font-size:17px;color:#111;cursor:pointer}" +
".tp-calc__ddOpt:hover{background:#f4f4f4}" +
".tp-calc__ddOpt.is-selected{background:#f0f0f0;font-weight:600}" +
".tp-calc__card{width:100%;background:var(--tp-card-bg);border-radius:var(--tp-card-radius);padding:44px}" +
".tp-calc__card .tp-calc__h{margin:0 0 4px}" +
".tp-calc__total{font-weight:800;font-size:60px;line-height:1;margin:10px 0 6px}" +
".tp-calc__etaRow{display:flex;justify-content:space-between;align-items:flex-start;gap:16px}" +
".tp-calc__etaVal{font-size:20px;font-weight:700;white-space:nowrap}" +
".tp-calc__spacer{height:26px}" +
".tp-calc__spacer--lg{height:40px}" +
".tp-calc__btn{margin-top:20px}" +
"@media (max-width:980px){.tp-calc__wrap{grid-template-columns:1fr;gap:28px}.tp-calc__card{padding:34px}}" +
"@media (max-width:520px){.tp-calc__card{padding:28px}.tp-calc__total{font-size:52px}}";
function decl(prop, val) { return val ? prop + ":" + val + " !important;" : ""; }
function buttonCSS() {
var B = CFG.button;
var base = decl("color", B.text) + decl("background-color", B.bg) + decl("border-color", B.border);
var hover = decl("color", B.hoverText) + decl("background-color", B.hoverBg) + decl("border-color", B.hoverBorder);
var out = "";
if (base) out += ".tp-calc a.tp-calc__btn{" + base + "}";
if (hover) out += ".tp-calc a.tp-calc__btn:hover{" + hover + "}";
return out;
function injectCSS() {
if (window.__tpCalcStyled) return;
window.__tpCalcStyled = true;
var st = document.createElement("style");
st.type = "text/css";
st.textContent = CSS + buttonCSS();
document.head.appendChild(st);
function el(tag, cls, txt) {
var e = document.createElement(tag);
if (cls) e.className = cls;
if (txt != null) e.textContent = txt;
return e;
function fmtNum(n) { return (+n).toLocaleString("en-US"); }
function heading(tag, txt, color) {
var e = el(tag, "tp-calc__h", txt);
if (color) e.style.color = color;
return e;
function smallP(txt, color) {
var e = el("p", "sqsrte-small tp-calc__sm", txt);
return e;
function round2(n) { return Math.round((+n + Number.EPSILON) * 100) / 100; }
function formatMoney(n) {
var F = CFG.formula;
var v = round2(n);
var d = Math.max(0, F.moneyDecimals | 0);
var fixed = v.toFixed(d);
var isInt = Math.abs(v - Math.round(v)) < 1e-9;
if (d > 0 && isInt) return F.currencySymbol + Math.round(v);
return F.currencySymbol + fixed;
function calcCost(w, d, s) {
if (typeof F.costFn === "function") return round2(F.costFn(w, d, s, F));
var rate = +F.rateByService[s] || 0;
return round2((+F.baseFee || 0) + w * d * rate);
function calcDays(w, d, s) {
if (typeof F.daysFn === "function") return F.daysFn(w, d, s, F);
var mpd = +F.milesPerDayByService[s] || 1;
return Math.ceil(d / mpd);
function clampInt(v, min, max) {
v = Math.round(+v);
if (!isFinite(v)) v = min;
return Math.min(max, Math.max(min, v));
function numField(o) {
var node = el("div", "tp-calc__field");
var row = el("div", "tp-calc__labelRow");
row.appendChild(heading(o.tag, o.label, CFG.colors.label));
var pill = el("div", "tp-calc__pill");
var input = el("input", "tp-calc__num");
input.type = "number";
input.min = o.r.min; input.max = o.r.max; input.step = o.r.step; input.value = o.r.value;
input.setAttribute("aria-label", o.label);
pill.appendChild(input);
pill.appendChild(el("span", null, o.unit));
row.appendChild(pill);
node.appendChild(row);
var range = el("input", "tp-calc__range");
range.type = "range";
range.min = o.r.min; range.max = o.r.max; range.step = o.r.step; range.value = o.r.value;
range.setAttribute("aria-label", o.label);
node.appendChild(range);
var mm = el("div", "tp-calc__minmax");
var s1 = el("span", "sqsrte-small", fmtNum(o.r.min) + " " + o.unit);
var s2 = el("span", "sqsrte-small", fmtNum(o.r.max) + " " + o.unit);
if (CFG.colors.smallText) { s1.style.color = CFG.colors.smallText; s2.style.color = CFG.colors.smallText; }
mm.appendChild(s1); mm.appendChild(s2);
node.appendChild(mm);
node.appendChild(smallP(o.hint, CFG.colors.smallText));
function get() {
var raw = input.value === "" ? o.r.min : input.value;
return clampInt(raw, o.r.min, o.r.max);
function fill() {
var v = +range.value, min = +range.min, max = +range.max;
range.style.setProperty("--tp-fill", ((v - min) / (max - min)) * 100 + "%");
function sync(v) { range.value = v; fill(); }
var cb = function () {};
input.addEventListener("input", function () { cb(); });
input.addEventListener("change", function () { input.value = get(); cb(); });
range.addEventListener("input", function () { input.value = range.value; cb(); });
return { node: node, get: get, sync: sync, onChange: function (f) { cb = f; } };
function serviceField() {
node.appendChild(heading(CFG.tags.serviceLabel, CFG.text.serviceLabel, CFG.colors.label));
var dd = el("div", "tp-calc__dd");
var ddBtn = el("button", "tp-calc__ddBtn");
ddBtn.type = "button";
ddBtn.setAttribute("aria-haspopup", "listbox");
ddBtn.setAttribute("aria-expanded", "false");
var lbl = el("span", null, CFG.services[0].label);
var chev = el("span", "tp-calc__chev");
chev.setAttribute("aria-hidden", "true");
ddBtn.appendChild(lbl); ddBtn.appendChild(chev);
var list = el("ul", "tp-calc__ddList");
list.setAttribute("role", "listbox");
list.hidden = true;
var current = CFG.services[0].value;
function open() { dd.classList.add("is-open"); list.hidden = false; ddBtn.setAttribute("aria-expanded", "true"); }
function close() { dd.classList.remove("is-open"); list.hidden = true; ddBtn.setAttribute("aria-expanded", "false"); }
CFG.services.forEach(function (s, i) {
var li = el("li", "tp-calc__ddOpt" + (i === 0 ? " is-selected" : ""), s.label);
li.setAttribute("role", "option");
li.setAttribute("data-value", s.value);
li.addEventListener("click", function () {
current = s.value;
lbl.textContent = s.label;
var all = list.querySelectorAll(".tp-calc__ddOpt");
for (var j = 0; j < all.length; j++) all[j].classList.remove("is-selected");
li.classList.add("is-selected");
close();
cb();
list.appendChild(li);
dd.appendChild(ddBtn); dd.appendChild(list);
node.appendChild(dd);
node.appendChild(smallP(CFG.text.serviceHint, CFG.colors.smallText));
ddBtn.addEventListener("click", function (e) {
e.stopPropagation();
if (dd.classList.contains("is-open")) close(); else open();
document.addEventListener("click", function (e) { if (!dd.contains(e.target)) close(); });
ddBtn.addEventListener("keydown", function (e) { if (e.key === "Escape") close(); });
return { node: node, get: function () { return current; }, onChange: function (f) { cb = f; } };
function mount(root) {
if (!root || root.dataset.tpDone === "1") return;
root.dataset.tpDone = "1";
var T = CFG.text, G = CFG.tags, K = CFG.colors, S = CFG.slider, R = CFG.ranges;
root.style.setProperty("--tp-card-bg", K.cardBg);
root.style.setProperty("--tp-track-fill", S.trackFill);
root.style.setProperty("--tp-track-empty", S.trackEmpty);
root.style.setProperty("--tp-thumb-bg", S.thumbBg);
root.style.setProperty("--tp-thumb-border", S.thumbBorder);
root.style.setProperty("--tp-track-h", S.trackHeight);
root.style.setProperty("--tp-thumb-size", S.thumbSize);
root.style.setProperty("--tp-input-w", CFG.layout.valueInputWidth);
var wrap = el("div", "tp-calc__wrap");
var left = el("div", "tp-calc__left");
var right = el("div", "tp-calc__right");
var title = heading(G.title, T.title, K.title);
title.classList.add("tp-calc__title");
left.appendChild(title);
var wField = numField({ label: T.weightLabel, tag: G.weightLabel, unit: T.weightUnit, hint: T.weightHint, r: R.weight });
left.appendChild(wField.node);
left.appendChild(el("div", "tp-calc__divider"));
var dField = numField({ label: T.distanceLabel, tag: G.distanceLabel, unit: T.distanceUnit, hint: T.distanceHint, r: R.distance });
left.appendChild(dField.node);
var sField = serviceField();
left.appendChild(sField.node);
var card = el("div", "tp-calc__card");
card.appendChild(heading(G.costHeading, T.costHeading, K.cardHeading));
var total = el("div", "tp-calc__total");
total.style.color = K.cardValue;
card.appendChild(total);
card.appendChild(smallP(T.costHint, K.cardMuted));
card.appendChild(el("div", "tp-calc__spacer"));
var etaRow = el("div", "tp-calc__etaRow");
var etaLeft = el("div");
etaLeft.appendChild(heading(G.etaLabel, T.etaLabel, K.cardHeading));
etaLeft.appendChild(smallP(T.etaHint, K.cardMuted));
var etaVal = el("div", "tp-calc__etaVal");
etaVal.style.color = K.cardValue;
etaRow.appendChild(etaLeft); etaRow.appendChild(etaVal);
card.appendChild(etaRow);
card.appendChild(el("div", "tp-calc__spacer tp-calc__spacer--lg"));
card.appendChild(heading(G.ctaHeading, T.ctaHeading, K.cardHeading));
card.appendChild(smallP(T.ctaHint, K.cardMuted));
var btn = el("a", "btn btn--border theme-btn--primary-inverse sqs-button-element--primary tp-calc__btn", T.ctaButton);
btn.setAttribute("href", T.ctaHref);
btn.setAttribute("rel", "noopener");
card.appendChild(btn);
right.appendChild(card);
wrap.appendChild(left); wrap.appendChild(right);
root.appendChild(wrap);
function recalc() {
var w = wField.get(), d = dField.get(), s = +sField.get() || 1;
wField.sync(w); dField.sync(d);
total.textContent = formatMoney(calcCost(w, d, s));
etaVal.textContent = calcDays(w, d, s) + " " + T.etaUnit;
wField.onChange(recalc);
dField.onChange(recalc);
sField.onChange(recalc);
recalc();
function init() {
var nodes = document.querySelectorAll("[data-tp-calc]");
for (var i = 0; i < nodes.length; i++) mount(nodes[i]);
function ready(fn) {
if (document.readyState !== "loading") fn();
else document.addEventListener("DOMContentLoaded", fn);
injectCSS();
ready(init);
if (!window.__tpCalcBound) {
window.__tpCalcBound = true;
window.addEventListener("mercury:load", init);
#2. Customize
#2.1. To change text, change line 06 – 25
text: {
weightUnit: "lbs",
etaUnit: "days",
ctaHref: "#"
#2.2. Style will inherit from Tags. You can set tags for all elements here (line 26 – 35)
tags: {
title: "h2",
weightLabel: "h3",
serviceLabel: "h3",
costHeading: "h3",
etaLabel: "h3",
ctaHeading: "h3"
#2.3. To change color, change line 36 – 45
colors: {
title: "",
label: "",
smallText: "",
cardBg: "#000000",
#2.4. To change scroll/track bar style, change line 46 – 53
slider: {
thumbBg: "#ffffff",
thumbSize: "26px"
#2.5. To change input width, change line 54 – 56
layout: {
#2.6. To change button style (it will inherit from Primary Button Style), you can change line 57 to line 65
button: {
text: "",
bg: "",
border: "",
hoverText: "",
hoverBg: "",
hoverBorder: ""
#2.7. To set Weight, Distance, change line 67 – 69
ranges: {
#2.8. To change Services dropdown value, change line 82 – 86
services: [
#2.9. To change formula, change line 70 – 81
formula: {
moneyDecimals: 2,
baseFee: 0,
costFn: null,
daysFn: null
For example, if you want to change Cost formula, change line 79
costFn: null,
to something like this
costFn: function (weight, distance, service, formula) {
return 5 + weight * 1.2 + distance * 0.03;
or similar with Days, we will change
daysFn: null
to
daysFn: function (weight, distance, service, formula) {
return Math.ceil(distance / 400) + 1;
You can ask AI adjust formula for you!
