The problem is that if I enable lazy loading for the widget, I can’t see the reviews in the Google search console. And consequently, Google can’t see the reviews’ snippets in search.
I turn off lazy loading, and everything is fine. The review snippet shows up in Google search, google also sees the reviews. However, this is very, very bad for page speed.
We’re happy to say that now the attribute for lazy loading is built in the installation codes of all our widgets, which doesn’t affect the schema functionality
