I would like to get the review schema (from my google reviews) from you so I can include it in my website for SEO purposes
Hi there, @user15735 ![]()
Schema markup is enabled in our Reviews widgets by default:
However, if it doesn’t work for you, please share a link to the page where your widget is installed. I’ll be happy to investigate it for you ![]()
