Currently only the most current review is added in schema markup. Create an option to pull other reviews into the schema.
Hi there and welcome to the Community, @user3374 ![]()
With the way markup works, it needs only one example review to fill the required markup field.
So, there’s no need to display all reviews in schema.org, as it already counts the overall number of reviews and the rating. Adding other reviews won’t change or affect your website’s SEO.
This is why the markup in our widget looks only for the first review with a rating higher than 4 that contains text and pulls it to the required field. If there are no reviews matching this condition, it simply takes the first review from your source.
Please let me know if this explains things or if you have any questions left ![]()
