Embed layout
Please add the Embed layout for the chatbot
Yes, this would be great. I’d like the option for the chatbot to be open already and embedded into the page it’s on.
Hi there, @Kate4 :wave:
Thanks for upvoting the idea! We’ll have it in mind and see for more votes from the community :wink:
Is there any way for my AI chatbot to show up on my page as the open dialog instead of having to click the button to open?
Hi there, @user21060 and welcome to the Community :wave:
Currently, unfortunately, it’s impossible to do this, but we already have a similar suggestion on the Wishlist.
I’ve moved your comment to the related discussion, where we’ll keep you in the loop :slightly_smiling_face:
This would be a great function, so that it can be placed for example in contact page as an alternative to the classical contact form
Nice point, @franco_zagorschi ! Thanks for sharing your thoughts with us :slightly_smiling_face:
Would like to see a chatbot that can be embedded into a landing page rather than a floating action button. We’d like to have our users go to this page for chat help but not have to take up real estate in the UI with the widget.
+1 please add this feature
Hey there, guys @itsupport_itsupport, @user23775 :waving_hand:
Thank you for the feedback!
We already have this idea on the Wishlist and I’ve added your comments there too :slightly_smiling_face:
We really like this option for us to properly use the chatbot. It would resolve our issue where we hit the limit of views very quickly (few days) because the chatbot is displayed on each page load.
The way we use the bot may be slightly different to others. We upload a JSON file with details of our products and customers can ask questions/search what they are looking for.
If we could embed the chatbot on a single page (ChatGPT style) this would reduce the unecessary amount of views for the bot.
This would be a great addition for us.
Got it, thanks for sharing your thoughts with us! We’ll keep this idea in mind and see for more votes from the community :slightly_smiling_face:
Just in case, I’d like to clarify that with the embed layout the widget will also be loaded on each page load and the amount of views will be reduced only if you install it to one page instead of all pages of your website.
However, the floating chatbot can be installed to specific pages as well :slightly_smiling_face:
Hey Max,
Currently we have the script loading on each page on our Mangento platform in the HTML head. Hence why it’s loading on all pages. This make sense if you wish to have the floating chatbot.
We were thinking more like embedding the script onto a single CMS page (like the Blog widget) and then only when user browses that page and use the Chatbot will a view be used.
It will also work well for us because we can use the whole page real estate for the chat conversation. Similar to ChatGPT.
Hope that makes sense.
Got you, thanks :slightly_smiling_face:
Would it be possible to get the ai chatbot as a static element rather than a floating widget? We’d like to put it on a virtual assistant landing page.
Hi there, @itsupport_itsupport :waving_hand:
Yep, this idea is already on the Wishlist, and I’ve merged your comment with it. If more users upvote this idea, we’ll try to think it over :slightly_smiling_face:
Just been thinking about this some more and throwing around some ideas. I do think that there should still be a popup widget option like we currently have. As some would like to use this.
Possibly a option in General where you can switch the chatbot between two modes.
  1. Popup widget style
  2. Embed on page
The embed on page idea that we are looking for would be similar to a ChatGPT or Gemini.
I have added a simple rough mockup of how it could look on the embed page.
Cheers.
Hi there, @Dave_12 :waving_hand:
No worries — if this feature gets released, it’ll just be an extra option alongside the current floating layout, not a replacement :slightly_smiling_face:
And I appreciate you sharing your example of how you envision the Embed layout - we’ll keep that in mind!
Hey @Max
No problem at all. If you or the devs want anymore feedback, just let me know. Or even early testing :wink:
While this is in the pipeline, would it be possible to bend the current chatbot to kind-of resemble the embedded version below? Possibly the devs have some magic custom css or js they could enlighten us with?
The only option to make it look like the embed version is to increase the height and width of the chat window using these codes:
