Issue description: When using AI chatbot in the embedded mode, why are there no close and expand buttons in the header? How can they be added?
Hi there, @user34755 ![]()
I’d like to clarify that this is expected behavior, not a bug.
The Embedded layout is designed to sit inline as a fixed part of the page, so it doesn’t have an “open/closed” state, and that’s why there’s no close/expand button in the header.
The close/expand controls are specific to the Floating layout, where the chat pops up over the page and toggles between a bubble and an open window.
Unfortunately, there is no custom solution to add these button to the Embedded layout, but I’ve added this suggestion to the Wishlist on your behalf: Add close/expand buttons to the embedded layout
If more users upvote it, we might think about it in the future ![]()
