AI Chatbot: Change color of each widget element, font, size settings and more! 🚀
We’re happy to announce that the AI Chatbot app is now even more customizable!
With the new settings, you have full control over the look and feel of your widget, allowing you to tailor it exactly to your needs :artist_palette:
What’s inside the update?
The widget now features a new theme control with 7 pre-designed themes.
Want to create something unique? Just click on the Customize Theme button to open a range of settings for tweaking the widget’s various elements:
Here’s what available now:
Launcher button
Customize the launcher button with new options like background color, icon color, and size to better fit your site’s design:
Header
The header now has customization settings for background, text, and avatar colors, so you can match it with your brand’s style:
Chat
You can now tweak various chat elements, such as the background, message colors, buttons, and corner radius, to create a fully personalized chat window:
Message field
Change the background, text color, border, and button color of the message field to ensure a clean and consistent user experience:
Footer
Easily adjust the footer text color to maintain harmony with your overall design:
Font
Choose the perfect font to align with your website’s style and enhance readability:
We hope these new options help you create a chatbot that truly reflects your brand. Let us know what you think — we’re eager to hear your feedback :blush:
Back to Changelog →
Hi @Max and Elfsight Team,
These are wonderful updates. Do you know if the Wish List has a “Full Screen Option” on it?
I had this experience with another chat bot I was using. It made the experience better since I was chatting with the bot initially then multiple humans from different departments in the same chat session for a long time.
I’d love to see Elfsight’s AI chat bot evolve to that level.
With thanks,
mw :man_technologist:t5: :sparkles:
Hi there, @iammasterweb :waving_hand:
Many thanks for sharing your thoughts!
I’ve added this idea to the Wishlist on your behalf - Make chat window full screen. If it gets more votes, we’ll try to consider it in the future updates :slightly_smiling_face:
As for now, we have a custom solution to make the chat window full screen - Make chat window full screen.
