Elfsight got affected by Cloudflare global network issues [Resolved]
Hello !
During the Elfsight maintenance, my AI chatbot widget stopped working and no longer appears on my website, contrary to what they say. :frowning:
Is it the same for you?
Hello @Arnaud_BOUVARD!
Unfortunately, we confirm the issue - due to global issues on the Cloudflare side, our service was also affected. We’re monitoring the situation and will keep you updated here :folded_hands:t2:
You can keep tabs on this here: Cloudflare Status - Cloudflare Global Network experiencing issues
Hi @Helga, I was following the matter live –> we experienced a huge increase in volume on our calculator, got updated via e-mail shortly after eachother that our calculator was about to go down due to the view limit on our plan. In between instant refreshes of the dashboard the views increased with 50+.
Is it possible to create a “status” page for us to check if something is going on server / widget wise?
Thanks!
When will widgets be back online?
Thank you for your comment, @StoreVanNederland_Be!
I’m really sorry about this situation, and I fully support the idea of adding a Status page. Right now, we don’t have it, but we have this suggestion in our Wishlist, and you’re welcome to upvote it here: Status Page
As for the current issue, you may track the progress here: Cloudflare Status - Cloudflare Global Network experiencing issues
I do hope we’ll have it sorted out soon :folded_hands:t2:
@Helga thanks for the quick reply. As a matter of fact we are online again! But the views haven’t been set back to the previous amount. So we are now still facing going down due to the view limit. Could you set it back to the amount we had before the issue struck?
Thanks!
Lars
Hi @Nick_Cao, it all depends on how fast Cloudflare resolves the issue on their end :pensive_face:
We just hope they’ll bring the fix as soon as possible :folded_hands:t2:
My apologies for the long wait, Lars!
Could you please contact our support team with this request? They will be happy to iron things out for you :slight_smile:
Hi @No_Faff_Marketing, we’re really sorry about this inconvenience :pensive_face:
Unfortunately, we got affected by the global issue on the Cloudflare side, and we’re waiting for them to apply a global fix. After that, all the widgets affected will be brought to normal.
I’ve moved your topic to another thread where we post updates on the situation so that you stay in the loop.
Hopefully, Cloudflare will resolve it soon :folded_hands:t2:
Ah, what a bummer, I get it. Thanks for confirming that this is the cause. Not much we can do, just wait!
@No_Faff_Marketing Alas, that’s correct, just waiting :weary_face:
Thanks a lot for your understanding!
The Community Calendar and Contact Form on my website are both down. Is there any ETA on getting this resolved? Thanks!
@Isa_Leshko I wish we had any ETA, but since the root cause is on the third party’s side, we’re just following their updates :sad_but_relieved_face:
According to their status page, they are “continuing working on restoring service for application services customers”. We’re just hopeful it won’t take hours :folded_hands:t2:
Friends, it should be getting back to normal now, here’s the latest update on the Cloudflare status page:
It works, thank’s !
Hey @Helga! Thanks for that. Yes, it will take approximately 24-48 hours for all of Cloudflare’s edge points (i.e., servers) to come back online. Cheers!
We have an official update on the Cloudflare status page confirming that the issue has been resolved:
Thanks, everyone, for your understanding! :folded_hands:t2:
