Customize number of Event Calendar events displayed for each layout?
I see that you can dynamically change the Event Calendar layout to use a single Event Calendar widget in multiple layouts all at once as explained here:
https://help.elfsight.com/article/1248-how-to-dynamically-change-the-event-calendar-layout
Can you also customize the number of events that are displayed for each individual Event Calendar layout?
Greetings @Bill4 :wave:
You’d like to display different number of events for different layouts using the dynamic layout feature, right?
Currently, there is no option to do this, but we have this idea on the Wishlist. Feel free to vote on this request :wink:
Thank you for your response; I voted!
Maybe I’m simplifying things here, but if you can manually apply a layout variable to specify the layout per view, couldn’t you also (manually) specify the “Number Of Events To Display” per view? I realize this wouldn’t be a permanent solution, but it’s at least a workaround to duplicating the entire widget and maintaining a separate widget for each view.
Regards,
-Bill
@Bill4 I’ve talked to the devs, but, unfortunately, it’s impossible to do this. I am really sorry!
If more users support the idea on the Wishlist, we’ll try to consider it in the future :slightly_smiling_face:
