A new way to work with text values is now available in the Calculator app! ![]()
With the latest update, you can now use the new Text field in your calculations and create more advanced scenarios — for example, applying discounts based on coupon codes or building calculators that depend on user-entered values.
Here’s what’s new:
New Text field for calculations
Use text values directly in formulas to make your calculators more dynamic and personalized:
New formula functions for working with text
New functions are now available in the formula editor to help you process and compare text values:
Have you already tried the new Text field? We’d love to hear what new calculator ideas it helps you build
