Aligned by height reviews are not displayed on Safari
It works perfect, but if I use the function then are the reviews not visible in Safari browser, only in Chrome.
Hi there @Henry1 :wave:
Could you please send me a direct link to the page where your widget is installed and specify the exact iOS and browser version? I’ll be happy to look into this for you :slightly_smiling_face:
Hello Max,
Sorry for my late response.
It is now visible on safari.
But the ‘read more’ button vibrates a bit and that is also the case on Chrome.
Hi @Henry1 :wave:
The thing is that the height of the card is calculated based on the line height value from the settings (which is the font size * 1.4).
I see that you’ve manually changed it on your site using the CSS code in the screenshot below. This is why the Read More button was flickering:
We’ve temporarily fixed it using this code in the Custom CSS field on the Appearance tab of your widget’s settings:
.es-review-content-text {
  line-height: 19px !important;
However, to fix it globally, you should remove the code you’ve added to your website.
Let me know if this explains things or if you have any questions left :slightly_smiling_face:
Thanks Max,
I’m gonna remove the CSS code.
Kind regards Henry
No sweat!
Have a great day :wink:
