Help with a widget design customization
Hello,
I would like to use a bold and highly legible font, similar to the examples shown in the screenshot I’ve attached. The current font looks too thin and low-impact for my brand style.
Additionally, I would like the background of the review boxes to be shorter. Right now, they stretch too far downward and appear oversized, which affects the visual balance.
Another issue is the “More” link inside the comments – it’s not clearly visible. I would like it to stand out more, like the “Give us a review on Google” button above it.
Finally, please let me know exactly which parts of the code I need to modify if I want to make further changes myself. That way, I won’t need to contact support for every small update.
Thank you in advance for your help.
Hi there, @Adnan_Aytekin :waving_hand:
  1. Do you want to apply the same font family to all widget elements and make the whole text bold? Or would you like to apply these changes only to specific elements?
  2. I see that you’ve applied the same height to all reviews using the CSS code, this is why shorter reviews have extra spacing in the review container. With the aligned height, it’s impossible to remove this space. I’d also like to let you know, that you don’t need to use a CSS code to align reviews by height because we have a setting for this:
By the way, you can reduce the Preview Text Length to change the review card height. The cards will still be aligned when changing this setting.
  1. To apply the styles of the Write a Review button to the Read More button, please use the CSS code below :slightly_smiling_face:
.es-text-shortener-control {
  padding: 8px 20px;
  border-radius: 22px;
  background-color: rgba(88, 133, 0, 0.94);
  color: #fff;
  text-overflow: ellipsis;
  overflow: hidden;
  white-space: nowrap;
  position: relative;
  max-width: 100%;
  text-decoration: none;
.es-text-shortener-control::before {
  content: '';
  position: absolute;
  inset: 0;
  background: rgba(0, 0, 0, 0);
  transition: background 0.3s;
.es-text-shortener-control:hover:before {
  background: rgba(255, 255, 255, 0.1);
Hello Max, Yes I would like to use same or diffirent font variabler, I tried gemini and chatgp, but does not work.
Can you please send me the necessary codes as a bold title and other name fonts like the ones in the screenshots I threw to you as an example, and I also wonder if you can design any known and existing font to try and see it easily and quickly without reaching you myself.
16 Haz 2025 Pzt, saat 17:37 tarihinde Max via Elfsight Community <notifications@elfsight.discoursemail.com> şunu yazdı:
Okay, here are the solutions to change the font family and font weight for all widget elements right away:
And here is the code to individually control the font family and font weight of all widget elements:
/* Header */
.es-header-heading-text {
  font-weight: 700;
  font-family: Times New Roman;
/* Rating */
.es-rating-value {
  font-weight: 500;
/* Review text */
.es-text-shortener {
font-weight: 700;
/* Write a Review button text */
[class*="ButtonBase__Ellipsis-sc"] {
  font-weight: 700;
/* Author name */
.es-review-author-name {
   font-weight: 700;
/* Date */
.es-review-info-date {
   font-weight: 700;
You’re very welcome to use any other font providing it’s supported by your browser and installed on your website. Please try it out and let me know if it worked for you :slightly_smiling_face:
Hello Max, I applied the codes which is sent your code, many thanks. There is a small problem about ^ read more^, you can see that there are three dots before ^ read more^… Can we solve it?
Max via Elfsight Community <notifications@elfsight.discoursemail.com>, 16 Haz 2025 Pzt, 20:16 tarihinde şunu yazdı:
This is a common practice to display the ellipse after the truncated reviews. This idea was on the Wishlist and we’ve recently released it - Add ellipse after truncated reviews.
So, this is the correct behavior rather than an issue. Would you still prefer to remove it from your widget?
