Ability to adjust review height
Ability to change the height of reviews and/or number of lines of text that show on the review
Hi there, @Emory_Clark :wave:
You can change the Preview text length on the Review tab of your widget’s settings:
Also, you can try out the Align Cards by Height option (right under the Preview Text Length setting). With this option all the review cards will get the same height.
