I tried updating the source to (7) Trinity Reformed Baptist Church - YouTube It does not like the /stream addition.
Hi there, @user22214 and welcome to the Community ![]()
By default, YouTube live streams aren’t displayed alongside regular videos in the widget. However, there are two ways to include them:
Create a separate playlist for your live streams and add the playlist URL to your widget.
Display live streams without manually creating a playlist. To do this, you can generate a URL that automatically pulls in live streams from your YouTube channel. Just follow the steps below:
Get your YouTube channel ID
Open the channel → click …more in the channel description:
Click Share channel → Copy channel ID:
For example, the channel ID for Elfsight Affiliates is UCGxFUjhwTm3KnLn1YKP6oHg.
Modify your channel ID
Replace UC in the channel ID with UULV. For example:
Original channel ID:
Converted channel ID:
UULVGxFUjhwTm3KnLn1YKP6oHg
Generate your live streams URL
Copy the new UULV-channel ID. Add it to the end of this URL template: https://www.youtube.com/playlist?list=. For example:
Blank URL template:
Completed URL template:
https://www.youtube.com/playlist?list=UULVGxFUjhwTm3KnLn1YKP6oHg
Add live stream URL to your widget
Go to the Source tab → leave the YouTube Channel URL field empty and click Source Group:
Click Add Source Group:
Click Add URL and paste the URL you created
That’s it! Your live streams should now appear in the widget.
Give it a try and let me know how it goes! ![]()
